Playlists should allow subscriptions to TV shows, so that new episodes are automatically added. Currently anytime a new episode is released, it needs to be manually added to the playlist. This function would work well for movie series, too.
You already can do this…
- go to the tv shows library in
Libraryview - select
Custom Filterin the filter dropdown - filter by
Show Title - create a playlist from that selection
This will create a smart playlist.
If you later add a new season (or new episodes) of that show, the playlist will automatically be updated to include those.
There’s a nice post in the tips & tricks section explaining this…
Edit:
if this works for you… should I close the suggestion and return your vote? ![]()
Thank you! I was not aware of this feature. Kind of an odd way to go about it, but it does work.
