Impossible to create a library with several sources
At home, in a server environment on Windows 10, it is not possible to add several multimedia folders as sources to create a library. Is it a bug or a problem of use on my part? In any case, it is very, very annoying.
Yes, it is possible.
Just “Add [another] Folder” when editing your library. https://support.plex.tv/articles/200289266-editing-libraries/
Thank you for your help, but this is what I do but I can’t get it to work at home. See copy of ectan
You cannot add individual series to a “TV Shows” library.
You must always add the “parent” folder which holds all the shows.
Thank you for your reactivity! I’m looking into it. I’m a bit new to PLEX and I regret the lack of a proper tutorial. Indexing, if you want to do itb properly is a complex matter.
It’s OK, you are the boss! Thank you
