I have a PC with 4 hard drives 1 drive for tv shows thats almost full , I adding a 2nd drive how do I set plex up so all tv shows are in 1 library thanks tony
- Edit the library (click
Manage Library>Edit…from the library’s context menu) - Open the
Add Foldertab - Add the tv-show library folder from the other drive/volume/location
As Tom states above, you can have 2 different folders in the same library, even if they’re on different drives. This is an easy way to add capacity without having to move everything.
