DTS 6.1 is now being displayed as 5.1 with Media Server 1.13.0.5003. Please Fix.
If you could provide a sample of the file (https://support.plex.tv/articles/201035968-generating-sample-files-from-media/) it would be super useful.
The few items I have with 6.1 DTS tracks seem to be working correctly on my side.
https://www.dropbox.com/s/j35eve1i6hfkq36/Gravity-001.mkv?dl=1
MediaInfo for whole File.
https://pastebin.com/raw/jkdfnYhL
@drzoidberg33 did you get a chance to test this?
Indeed, thank you very much for the sample. The issue has been logged internally. Can you 100% confirm this was working correctly before 1.13.0, I didn’t have a chance to test that?
I upgraded from 1.12.3.4947 where it was working fine.
I have the same problem since 1.13
This is still broken…
I’ve the same Problem still with Version 1.13.2.5102. MediaInfo Shows
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format-Profil : HRA / Core
Codec-ID : A_DTS
Dauer : 10s 16 ms
Bitraten-Modus : konstant
Bitrate : 2 046 kb/s / 1 509 kb/s
Kanäle : 8 Kanäle / 6 Kanäle
Kanal-Positionen : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Samplingrate : 48,0 kHz
Bildwiederholungsrate : 93,750 FPS (512 SPF)
BitDepth/String : 24 bits
Stream-Größe : 2,44 MiB (8%)
Titel : Surround 7.1
Sprache : Deutsch
Default : Ja
Forced : Nein
But Plex Reports DTS 3.1 what is wrong!
Sample file https://www.file-upload.net/download-13164787/JasonBourne2016.mkv.html
It works now with Version 1.13.2.5154. Plex is showing DTS 7.1!
