Incorrect Group and Permissions on renderD128 on official Docker Container
Server Version#: 1.41.4.9463
Player Version#: NA
I’ve migrated my Plex docker container (plexinc/pms-docker:plexpass) from an older Intel i7-4700K Ubuntu 24.04 desktop to an unprivileged LXC running on Proxmox 8.3.3 (Intel i7-8700, 6.8.12-8-pve). The LXC is Debian Bookworm 12 with all recent updates as of Feb 16, 2025. I’ve given the LXC 4 CPUs, 4GB of RAM, and 60GB of disk space. I’ve also passed through my Intel A380 GPU using the new features in PVE 8.3 where you only need to share the /dev/dri/card# and /dev/dri/renderD12#. On the LXC, I’m running Docker. In my compose.yaml file, I’ve got the following:
      devices:
        - /dev/dri:/dev/dri
#        - /dev/dri/card3:/dev/dri/card3
#        - /dev/dri/renderD129:/dev/dri/renderD129
You can see I’ve tried the individual card and renderD names, but they produced the same results. So I went with what is officially documented here. My issue is that Plex will not utilize the Arc380 for transcoding at all. It detects it in the TRANSCODING settings page as INTEL DG2 [Arc A380]. What’s strange is that if I go into the container, I can see the following permissions/groups on /dev/dri:
root@plex:/dev/dri# ls -lha
total 0
drwxr-xr-x 2 root root        80 Feb 17 16:30 .
drwxr-xr-x 6 root root       360 Feb 17 16:30 ..
crw-rw---- 1 root video 226,   3 Feb 17 16:30 card3
crw-rw---- 1 root   104 226, 129 Feb 17 16:30 renderD129
root@plex:/dev/dri#
You can see here that the container has no “render” group and is listing the GID for the LXC container. I don’t even see a render group in the container at all, only a video group:
root@plex:/# cat /etc/group | grep render
root@plex:/# cat /etc/group | grep video
video:x:44:
root@plex:/#
If I chmod 666 /dev/dri/renderD129 then the transcoding operation works as expected. If I reboot the LXC container, I lose that chmod setting and I have to manually change it again. What am I missing here? Should the renderD129 node be a member of video?? Is that the default? If so, what do I need to do to change this? Thanks for your help!
I have discovered that I can manually add the render group to the container:
docker exec -it plex-container bash
groupadd -g 104 render
usermod -aG video,render plex
I can then reboot the LXC container and the render group still exists and the plex user is still a member. But, I don’t think I should have had to do this. Unless I’ve got a super messed up config of my LXC and plex docker container. Also, what happens when the plex container needs to update? I would appreciate any help here. Thank you!
