incorrect match problems
IMDB and TVDB missing from match / incorrect match search anyone any ideas , just says loading in the drop downs
you’re very vague as to what actually isn’t working…
do you have your media files named according to the Plex conventions (see media preparation)? if so and if the movie is listed, auto-matching should work right away.
when you click on incorrect match and then go to search options the two boxes on the right, agent and language just say loading instead of IMDB TVDB etc
