Indirect Connection due to work Firewall
Hi Plex Community & Team,
I currently host a PMS on my home network and have set up Remote Access. It works perfectly on any device and most networks. E.g. Mobile data, McDonald’s WiFi, my friend’s home networks. I am using the default port 32400 and have forwarded this in my router.
On my work network, I only get indirect connections and it falls back to relay.
I suspect this is because my work network blocks certain outgoing/incoming ports.
What are all the ports Plex uses or may cause it to fallback to Relay?
Or has anyone had similar issues before?
Thank you.
Server Version#: Any
Player Version#: Any
Plex Media Server Logs_2023-12-11_14-18-27.zip (1.3 MB)
See these two threads:
