I have used Plex in Windows with no problems and would like to install it to my Raspberry Pi. Presently I am using a 200 GB SD card with Retropie as the bootup and a link in it to Raspbian and also a link to Kodi. I would like to add Plex as well, but there is no way I am re-imaging a card for it, as I am trying to make it all accessible from this card without switching cards. Is the only way to install Rasplex by installing to a empty card and not as a download install? If so, will just have to forget about it then.
Well, if you want to install it to an empty card just swap SD
if not you need to use Noobs or something like that. If you are already using it for kodi and raspbian it shouldnt be that hard to add it, if not you should better back up your retropie
No, the point is I do not want to install to an empty card or noobs. I just wanted to install it by downloading and installing to add onto the installation I already have.
no, that´s impossible with rasplex
you have to use a multiboot solution
You can use the plex kodi plugin to get your plex content into kodi. That seems to be your only option afaik.
There is an official plugin, but for plexpass users only at the moment. You can also try plexkodiconnect.
Does the plex kodi plugin work with the retropie version of kodi?
I was looking for something similar but have 3 SD cards I was going to use, 1 for Rasplex, 1 for Rasbian and 1 for retropie as I would like ot fiddle and mess around. But if I can get plex on the retropie kodi app I can reduce to 2 cards.
@LFFPicard said:
@thommy86 said:
You can use the plex kodi plugin to get your plex content into kodi. That seems to be your only option afaik.Does the plex kodi plugin work with the retropie version of kodi?
You can have all of them on just one SD if you start from scratch
Which its a good idea for @invincer too if he backs up the home directory
