Hi everyone
Have been using PlexConnect on a freeNAS box previously however with the new updates in their system it broke the old commands i used to install and run PlexConnect.
I thought i would list the commands that i have used so far to install the components however i have got stuck when i come to try and run a python or bash which i was wondering if someone with more experience would be able to help me with?
So to install git, python, nano and bash i used the following:
pkg install git pkg install python pkg install nano pkg install bash
All installed fine. Next i cloned PlexConnect using the following:
git clone https://github.com/iBaa/PlexConnect.git
All good so far.
I next cd'ed into the PlexConnect folder and then tryed to run PlexConnect.py. This is the error that i got.
root@PlexConnect:/PlexConnect # ./PlexConnect.py env: python: No such file or directory root@PlexConnect:/PlexConnect #
I though ok i will just copy my old 'Settings.cfg' and cert into the correct folders and then just start the service using
bash /PlexConnect/PlexConnect_daemon.bash start
I then got this error:
root@PlexConnect:/PlexConnect # bash /PlexConnect/PlexConnect_daemon.bash start Starting PlexConnect... /PlexConnect/PlexConnect_daemon.bash: line 29: python: command not found root@PlexConnect:/PlexConnect #
I have now reached the extent of my knowledge and am unsure as to what to do.
Your thoughts and advice are appreciated.
