Install question
I'm trying to install Plex onto my ATV2 and followed the instructions but when I run the plexconnect.py file I get an error.  I attached a screen shot of my data log.  Everything went great up until this snag.  Can anyone help please?
Thanks a lot!
Moving to the PlexConnect forum :)
Looks like you need to check the permissions of the plexconnect-master folder as it’s failing when it tries to create the settings.cfg file
Right clic on your "plexconnect-master" folder -> properties -> security -> add "full controll" for Everyone.
(On Win 7 and later, if you want to add a folder/files in "program files", you have to modify the permissions then.)
It worked!  You're a genius.  Thanks for the help!
Question solved!
