plexconnect.py failing to open settings.cfg
can anyone shed some light on this?  I checked the permissions settings for the settings.cfg file and set the users group to Full Access. I am running this on Windows7 32Bit.
Thanks!
C:\Program Files\PlexConnect-master>plexconnect.py
09:21:16 PlexConnect: ***
09:21:16 PlexConnect: PlexConnect
09:21:16 PlexConnect: Press CTRL-C to shut down.
09:21:16 Settings: add setting enable_plexgdm=True
09:21:16 Settings: add setting ip_pms=192.168.178.10
09:21:16 Settings: add setting port_pms=32400
09:21:16 Settings: add setting enable_dnsserver=True
09:21:16 Settings: add setting port_dnsserver=53
09:21:16 Settings: add setting ip_dnsmaster=8.8.8.8
09:21:16 Settings: add setting prevent_atv_update=True
09:21:16 Settings: add setting enable_plexconnect_autodetect=True
09:21:16 Settings: add setting ip_plexconnect=0.0.0.0
09:21:16 Settings: add setting hosttointercept=trailers.apple.com
09:21:16 Settings: add setting port_webserver=80
09:21:16 Settings: add setting enable_webserver_ssl=True
09:21:16 Settings: add setting port_ssl=443
09:21:16 Settings: add setting certfile=./assets/certificates/trailers.pem
09:21:16 Settings: add setting loglevel=Normal
09:21:16 Settings: add setting logpath=.
Traceback (most recent call last):
  File "C:\Program Files\PlexConnect-master\PlexConnect.py", line 170, in
    success = startup()
  File "C:\Program Files\PlexConnect-master\PlexConnect.py", line 53, in startup
    cfg = Settings.CSettings()
  File “C:\Program Files\PlexConnect-master\Settings.py”, line 60, in init
    self.checkSection()
  File “C:\Program Files\PlexConnect-master\Settings.py”, line 102, in checkSect
ion
    self.saveSettings()
  File “C:\Program Files\PlexConnect-master\Settings.py”, line 71, in saveSettin
gs
    f = open(self.getSettingsFile(), ‘wb’)
IOError: [Errno 13] Permission denied: ‘C:\Program Files\PlexConnect-master\S
ettings.cfg’
Fixed! I forgot to set the python.exe to run as administrator.
