installation failed
I try to install rasplex using get rasplex for windows, the last one.
i format the sd card with sd format first .
i start the program get rasplex and at the end it tell me that’s ok but need to format a second partition. i accept.
when i put the sd in the raspberry3 i stay on the first color screen.
I try with 2 differents sd card : same issue.
Do you have any idea ?
thanks
you dont need to format the SD, all it will be done by the installer
what installer are you using?
