Installing DVR Beta Fails
Hi
I finally bit the bullet and am jumping into the DVR Pool…
Currently running 1.3.3 PMS
When installing it says I have a newer version and stops install
It tells me I have to remove the Current PMS and install the beta version.
Sorta afraid to do this…
What will happen to my Library??
Will I lose my existing library and have to rebuild it??
If so…
How do I prevent That?
No, your settings for your library will be retained when you do the uninstall/reinstall. Many others have done this without issue.
@adamskoog
Thanks so much!!!
Needed to hear that to alleviate my anxiety over the uninstall
LOL…
