Intel UHD Graphic 630 VS Intel HD Graphic 630 - Hardware Transcodierung
Hi Zusammen
Hat jemand von euch schon Erfahrungen sammeln können, bezüglich der Leistungsunterschiede beim Hardware-Transcodieren zwischen den Kaby-Lake Prozessoren mit Intel HD Graphics 630
und den neueren Coffe-Lake`s mit Intel UHD Graphics 630 ?
Habe Im Netz nur vergleiche in Punkto Gaming gefunden, was mich weniger interessiert.
Beim Gaming allerdings, sind beide etwa gleich auf. Die Unterschiede sind marginal.
Beste Grüsse
Ich spreche nicht Deutsch but maybe this help @ https://en.wikipedia.org/wiki/Intel_Quick_Sync_Video
Thank you for Answer
my question was, are there performance differences between UHD 630 vs HD 630 when hardware transcoding?
I only found comparisons regarding gaming.
Ahh, I do not know for certain, but I would expect that they would be the same or very close since they are the same generation.
Looks like they are essentially the same. Same feature set. UHD has slightly higher max clock on some models.
https://www.notebookcheck.net/HD-Graphics-630-vs-UHD-Graphics-630-vs-HD-Graphics-P630_7652_8126_7657.247598.0.html
If you really want to dig into the details, pull up the datasheets for the processors. The info is usually in Datasheet Vol 1, in the “Processor Graphics” section (usually section 2.4). It has tables showing max resolution, supported profiles & levels, etc. FYI, be sure & pull datasheet for the CPU, not the chipset (they both have a “Datasheet Vol 1”).
Look at the comparison charts to see which graphics is in which CPU (HD630 in 7th Gen, UHD630 in 8th+ gen).
