Is there any way to intercept dns requests to other services?
To quickly explain what I need -
I live in Denmark, which adds a need to use unblock-us to redirect certain traffic through a different DNS to access otherwise localization blocked content such as Pandora, US Netflix etc.
I have Plex and Plexconnect setup on my QNAP and it works like a charm. However, as it stands, I use the Unblock-us dns as the dns to route all other traffic through, however, I would like to change that to my ISP dns (So I can access the danish Netflix through my Apple TV 3), but in doing so, I will be unable to connect to Pandora. Is there a way to intercept traffic sent to Pandora and redirect it to another DNS?
My ISP DNS - 194.239.134.83
Unblock-US - 208.122.23.22
Anyway to selectively intercept dns lookups for pandora.com through a specific dns?
Unblockus lets you select which Netflix region to watch when you use their DNS. You just go to their site and choose from a drop down menu. So you should be able to watch Dutch Netflix and use Pandora with your current setup. When you want US Netflix again go back to the web site and select that.
EDIT: just realized you are in Denmark, not sure if Unblockus supports that region yet. I am using Unotelly now so I can’t check. I do know that Unotelly supports Denmark though.
Ahh, it's been a while since I was actually on the unblock-us site as I know the DNS by memory - So I hadn't noticed that they made a switch between regions without having to change the DNS IP...that's pretty awesome and does exactly what I need it to do. Thanks for the heads up :)
