interesting error starting plexconnect w7.
C:\Python27\PlexConnect-XML_templates>plexconnect.py
PlexConnect : ***
PlexConnect : PlexConnect
PlexConnect : Press ENTER to shut down.
PlexConnect : ***
PlexConnect : IP_self: 192.168.1.108
DNSServer : Failed to create socket on UDP port 49152: [Errno 10048] Only one us
age of each socket address (protocol/network address/port) is normally permitted
PlexConnect : DNSServer not alive. Shutting down.
Looks like wininnit.exe is using port 49152 for me.  I read that you can make windows use different ports, but is there anyway to get plexconnect to run on a different port?
Try rebooting your machine, it should sort out your issue.
Nope no dice, same thing, odd that it's wininnit.exe binding it.
ok I found a fix I just did a netstat -a and looked for a 491xx port that was open, for me I chose 49160, I then went into the plexconnectxml folder and edited the dnsserver.py file and where it says port 49152 I just changed that to 49160 and it's all working now.  We can mark this as closed and hopefully it will help others if they come across this bug.
