Running Two Instances of PlexConnect?
Is it possible to run two instances of PlexConnect on two different computers on the same network? If so, what do I need to configure?
I keep on getting UDP port already used error.
yes you can, I get that udp error about port 49150 or whatever it is already in use (not sure why and it happens randomly after a reboot) what I do is just go into the dns settings and search for that 49150 or whatever port it is and I change to 49160 or something about 10 higher, and it fixes it.
I don't know the source of the described issue... but why would you want to run two instances?
well like some of us have 2 plex servers ... and while we are waiting for myplex implementation
one plexconnect for each server ?
Mr. Latte
where you change these dns settings ?
If you are having the same error as I am read this post I created on how to fix it.  http://forums.plexapp.com/index.php/topic/69975-interesting-error-starting-plexconnect-w7/
