Windows 8 - 64
ATV 3
please help I'm having this errors:
Windows 8 - 64
ATV 3
I have the same issue on a Windows 8 P.C.
You need python 2.x, that looks as if you have installed 3.x
Thanks f00b4r that fixed me.
almost there...
now I have "No response from Plex Media Server" on my ATV screen
thanks
For some reason it is not finding your PMS automatically.
Check that you have GDM enabled in the PMS settings (use Plex web) and multicast is enabled in your router.
Alternatively you can hard code your PMS IP in settings.py, change 192.168.178.2 to the IP of your PMS.
thanks!
i was getting the same "No response from Plex Media Server"
upgrading my router's (linksys e300) firmware fixed it.
many thanks to the plex team for releasing these scripts!
