Unable to launch PlexConnect.py
TIA
Upon launch I receive the following error:
Traceback (most recent call last):
  File "C:\Users\Sean\Downloads\PlexConnect-0.1-iOS-pre5.1\PlexConnect-0.1-iOS-p
re5.1\PlexConnect.py", line 16, in
    import PlexGDM
re5.1\PlexGDM.py", line 120
    print "IP:", getIP_PMS()
SyntaxError: invalid syntax
Support Template
ATV Model 2
fw version 5.3(6105)
DNS on ATV: 10.0.1.169
Plex Connect OS: Windows 7
local IP: 10.0.1.169
PMS OS: Windows 7
Media Storage: internal drive
PlexConnect version: PlexConnect-0.1-iOS-pre5.1
Cannot find Settings.cfg file
Crap, sorry guys.
ATV3 not 2
OK,
I'm reading impared apparently.  I had installed the wrong version of Python.  Got the correct version installed but now I receive the following.
C:\plexconnect\pc>plexconnect.py
21:00:51 PlexConnect: started: 21:00:51
21:00:51 PlexConnect: ***
21:00:51 PlexConnect: PlexConnect
21:00:51 PlexConnect: Press ENTER to shut down.
21:00:51 PlexConnect: IP_self: 10.0.1.169
21:00:51 PlexGDM: ***
21:00:51 PlexGDM: looking up Plex Media Server
21:00:52 PlexGDM: servers discovered: 1
21:00:52 PlexConnect: PMS: 10.0.1.169:32400
21:00:52 DNSServer: started: 21:00:52
21:00:52 DNSServer: Failed to create socket on UDP port 49152: [Errno 10048] Onl
y one usage of each socket address (protocol/network address/port) is normally p
ermitted
21:00:52 PlexConnect: DNSServer not alive. Shutting down.
http://forums.plexapp.com/index.php/topic/69975-interesting-error-starting-plexconnect-w7/?hl=49152
Now I get, trailers is unavailable.  Try again later.  From my ATV3....
TIA
This message occurs when trying to access
TIA
Error occurs when trying to access trailers from ATV3....
restarted plexconnect.py
issue solved.
...this thread is one great example of community help & support, isn't it?
:-D
