iOS player reporting corrupt database
Server Version#: Version 1.21.1.3876
Player Version#: 7.11
I started getting messages that my Plex database is currupted. It seems to show when im doing scheduled tasks and it only shows on my iPhone.
I found another post about this but it seems to have been closed without any answer last year.
is this actually a database corruption problem or some other kind of bug? I wonder why the server does not tell me anything?
Sounds like you enabled the notifications …
You better check to find out. Plex will go south fast if the database is corrupted… luckily there’s a chance you can repair it:
Yes im using notifications, but should I not be able to see this server side too?
And I have seen this one before but which one do I use for a Synology NAS? Linux?
Thank you so much for your answer :blush:
Here you go… closest to the Linux instructions but with Synology we can always use the specific FAQ :wink:
You should be able to attempt a repair based on the Linux instructions via SSH. If that fails…
