FAQ 17: Recover from a corrupt database
On Synology NAS machines, we have direct GUI access to the database area.
We can use File Station to recover if PMS was previously able to make database backups
Open Control Panel - Shared Folders - EDIT the Plex share
a. Permissions tab
b. Give your username R/W permission to the Plex share
Open File Station
Navigate to the databases folder
DSM 6: Plex / Library / Application Support / Plex Media Server / Plug-in Support / Databases
DSM 7: PlexMediaServer / AppData / Plex Media Server / Plug-in Support / Databases
4. If you have corresponding .wal or .shm for the main Database file, delete them
Rename com.plexapp.plugins.library.db to com.plexapp.plugins.library.db-damaged
Due to how Synology handles making copies of files (Skip or Overwrite only),
a. Copy your most recent backup to another folder somewhere
b. Rename it to add-copy
to the name
c. Move the renamed copy back here.
Rename it to be the original, proper, name
Right-click com.plexapp.plugins.library.db → Properties
Set the owner to be plex . (It will have changed when you made a copy)
Start Plex
Scan Files to bring the database back into sync with your current media status
When you are satisfied the -damaged file is no longer needed, you can delete it.
