Hello.
Since upgrading to the latest version a few days ago, I have noticed a problem with Cigaras IPTV addon
I use iptv addon to make a custom m3u list of Apple keynote streams. Up until now there were no problems with any of the streams. Since the upgrade to Plex app v.2.007 (Samsung TV) I have noticed that I can’t play some of them. Anything prior from March 2015 event works (including the March 2015), but anything later then that won’t. This all works fine with the latest (1.3.4 server and 4.7 iOS) clients on my mac and ios device.
What are the type of links in your playlist ? .m3u8 or .mp4 ?
I had a look at a Sept 2016 event page http://www.apple.com/apple-events/september-2016/ and the video is an mp4. The IPTV playback call uses HTTPLiveStreamURL which I understand should only work with .m3u8’s. It’s odd to me that it works on your other clients unless they have a fallback mode that kicks in or the core method is same for both types.
You can either ask the author to add a case for mp4 videos or define one in the code yourself.
Thank you for your reply. All streams (the ones that are working and the ones that dont are m3u8. To make matter worse it all worked just fine on 2.006 version of Plex client for Samsung. On the other hand I did kept my plex server side up to date all the time so it could be that it stopped working at some point due to some changes there.
It doesn’t explain why it works with some streams and not all. Also, yes, it works just fine via plex web, ios and mac app (all up to date). I have tried to update the addon as well, but no change.
I did have issues with the Samsung App when upgrading. Generally when all else fails I do an uninstall, smarthub reset, disconnect wire - 2min., re-install.
You might also want to post 1 working and 1 non-working m3u8 link from your list. I can check on it as well.
