Is QNAP TS-453D 64-bit support or not supported anymore?
Sorry, this is probably a duplicate but I can’t search/find the answer. I have a QNAP TS-453D which is 64-bit and runs QTS 5.2.3.3006. Is Plex no longer supporting this? I fully understand the upgrade to requiring Glibc 2.14.1.
Thanks,
-Scott
Still supported
PMS uses MUSL and therefore independent of GLIBC version
Thanks for that help. All my Plex apps (iPhone/iPad) say the QNAP Plex server is not current enough to support their use (need 1.41.2 or newer), but AppleTV Plex Player and MacOS Plex Player are still working fine. Do I just need to wait for a Plex update for QNAP? Plex on QNAP says 1.30.0 with no option to update.
Thanks,
-Scott
Download this (the master qpkg file).
Go into App Center.
Perform a Manual Install using this file.
App Center will install this as an upgrade.
https://downloads.plex.tv/plex-media-server-new/1.41.6.9685-d301f511a/qnap/PlexMediaServer-1.41.6.9685-d301f511a-x86_64.qpkg
We are working with QNAP to get PMS updated in App Center.
I’ve been on the Internet since 1986 downloading software from SUMEX-AIM (Stanford) to my dorm room in NH… This is the fastest resolution to a software issue I’ve ever received. I’d love to buy you a coffee if you can tell me how to get a Starbucks card to you (do you drink coffee?). My apps are all up and running fine now!
Thanks,
-Scott
@ChuckPa is awesome.
