Is the constant buffering normal?
Hello everyone,
Server Version#: 1.16.5.1552
Player Version#: Plex for Samsung 4.5.1
I put my server on a NAS Synology DS918+ thinking it would be a good NAS for 4k streaming.
But I have constant buffering for huge movie files (50Go - UHD 4k - Atmos 7.1 - HDR 10 - HEVC)
Everything is on the same network, 1Gbit. The TV is a Samsung QLED 8k 65" QE65Q950RB.
In the dashboard it doesn’t seem I have problem with the CPU usage but if I check the verbose log, I find speed around 0.3 or 0.4 which seem to point to the CPU as the problem (can’t transcode fast enough)
plex|690x771
I don’t have any problem on “normal” size file for 1080p.
I also tried with the plex server on my i9 9900k 32Go RAM nvidia 2080, and I still have minor quick buffering (withe some dropped frames).
Am I a bit too ambitious? Is there something I can change (use hardware when available is checked)?
Thank you for any information you can provide!
Hello,
The buffering problem starts instantly as I start the movie.
You’ll find the logs attached, hope it will help. If I have to provide something else, let me know.
Thank you very much
There is the XML:
Media
Duration 2:09:23
Bitrate 57446 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Video Resolution 4K
Container MKV
Video Frame Rate 24p
Video Profile main 10
Part
Duration 2:09:23
File Spider-Man.Far.From.Home.2019.MULTi.2160p.UHD.BluRay.REMUX.HDR.HEVC.TrueHD.Atmos.7.1-TOXIC.mkv
Size 51.95 GB
Container MKV
Codec HEVC
Bitrate 53656 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
Level 5.1
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K (HEVC Main 10 HDR)
Codec TRUEHD
Channels 8
Bitrate 3077 kbps
Language English
Audio Channel Layout 7.1
Bit Depth 24
Sampling Rate 48000 Hz
Title TrueHD Atmos 7.1
Display Title English (TRUEHD 7.1)
Codec AC3
Channels 6
Bitrate 640 kbps
Language Français
Audio Channel Layout 5.1(side)
Title AC3 5.1
Display Title Français (AC3 5.1)
Codec PGS
Language Français
Header Compression true
Title Forced
Display Title Français (PGS)
Codec PGS
Bitrate 31 kbps
Language Français
Title French
Codec PGS
Bitrate 42 kbps
Language English
Title Anglais
Display Title English (PGS)
Plex Media Server Logs_2019-09-23_07-51-52.zip (2.1 MB)
Sorry for the verbose, I will definitely turn this option off. I was using it following the help on plex website and forgot to turn it off and make a new log.
For the subtitles, I’ll use the plex feature to get subtitles in srt. Thanks for the info.
For the audio, I already have an Anthem MRX 1120 but I don’t have the speakers. Will definitely use passthrough when my system is up and ready. Thanks again for the info.
For the video transcoding/direct play, I’ll try to use Handbrake to have a compatible format for my TV if changing the subtitles doesn’t help much.
Thank you again for your precise answers.
Well, looking at my TV specifications, it should be able to play HEVC level 5.1 so I hope it’s only a problem of subtitles.
