Is there a way to edit recordings?
Is there a way to edit DVR recordings (or any other video, for that matter)?
Or just set IN/OUT points to avoid commercials?
I could put them into Quicktime player and resave trimmed clips, but a feature to simply set IN/OUT points would be great.
Plex does not have functionality to modify recordings.
You can use a 3rd party post processing script to mark them or cut them out if you want.
I use mcebuddy since I am running Windows. You can put together a similar process using Comskip, ffmpeg, and Handbrake if you want this ability. Have seen other threads on forum discussing post processing on other platforms.
Thank you. Will look into it.
