Hey there plex users,
Just had one question that has been bugging for awhile and I cant find a solution to it, so I have different users and I want to be able to import playlist into another users profile instead making it all up again it this possible? Also while I’m here is there a way to import watched and unwatched content to another user?
Thanks guys.
I have gotten half way there, I have exported the playlist that I want to use in another plex user, but I have not yet found a solution for re-importing it.
The way I have exported it is I used webtool (unsupported app store) and used a used tool called Export tools.
Let me know if you guys have found a way to re-import the CSV file into plex.
Switch to the developer version of WebTools (or wait until it is released).
It has a way to copy playlists to other user accounts.
(Smart playlists are converted to dumb playlists though)
Ok cool @OttoKerner how do I switch to the developer version?
switch the ‘branch’ to “translate”:
then download the zip and replace your current plugin
You can use a python script to share playlists to shared users. Here is the script. And here is a fun playlist idea.
