Is there a way to install Plex on the DS218Play?
If you want to access from outside your local network, you must also redirect port 16621. Greetings.
Hi, I am struggling with this too. What do you mean by “redirectioned in my router to the port 32400 tcp/udp the ip of my Synology”?
Open the Port 32400 in the router??
port 16621 is not a standard, fixed Plex port. That’s most likely UPnP and therefore transient. No need to add it.
On your modem/router, if it does not have UPnP/NAT-PMP,
Create a manual Port Forwarding rule to forward port 32400 to the IP address of your Syno also port 32400. Protocol is TCP. UDP is not required.
Ok. Thanks you.
