Hello,
Following up tangentially on the discussion below. I often have a similar issue where my plex is running on my qnap, but will be unavailable. I full restart usually remedy’s this problem. However I’m wondering I can get ahead of it.
Does anyone know of a software or script that would alert you if you plex is offline, which would prompt you to then restart it?
Thanks!
Chris
Continuing the discussion from Plex regularly unavailable but shows as running on Qnap:
Server Version#:
