Is there really no way to edit the 'actors' manually?
I thought that its even possible to add /change an actor in the same way as Genres, Regis, country, etc.
Is there a special work-around solution, or am I blind?
no, you are not blind ... it's just not supported ... only plex dev's knows why..^^
I'm really surprised! Is here nobody else missing this feature??
no , u dont..
I very much miss this feature...  Make sure to "complain" here, in case some dev reads us and makes it happen: ;)
https://forums.plex.tv/topic/88482-feature-request-editing-cast-lists/
Can't the xml be modified directly? Just guessing without looking into it.
