Issue accessing plex web ui
I had PMS running on Windows for years, but I decided to switch to Unraid. So far I am really liking it but I am having issues with running PMS.
I am running the official pms-docker:plexpass and it worked the first time I installed it. I bought more HDDs and extra SSD so I decided to uninstall PMS and reinstall it after adding the new drives.
The install goes fine but I cannot access the web UI. I checked the logs but I don’t see anything in them to help me figure out what is causing this issue.
Like I said this is a fresh PMS install so if I need to wipe something I am willing to do so but I have Sonarr, Radarr, and other containers working fine without issues.
I did notice that the Network Type got setup as “host” but all my other containers are set to “bridge”
Server Version#: current plex pass version
Log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 40-plex-first-run: executing...
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing...
/plex-common.sh: line 26: declare: warning: remoteVersion: circular name reference
/plex-common.sh: line 26: warning: remoteVersion: circular name reference
/plex-common.sh: line 27: declare: warning: remoteFile: circular name reference
/plex-common.sh: line 27: warning: remoteFile: circular name reference
/plex-common.sh: line 54: warning: remoteVersion: circular name reference
/plex-common.sh: line 55: warning: remoteFile: circular name reference
Attempting to upgrade to: 1.21.2.3943-a91458577
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
Selecting previously unselected package plexmediaserver.
(Reading database ... 7262 files and directories currently installed.)
Preparing to unpack /tmp/plexmediaserver.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Docker detected. Preinstallation validation not required.
Unpacking plexmediaserver (1.21.2.3943-a91458577) ...
Setting up plexmediaserver (1.21.2.3943-a91458577) ...
PlexMediaServer install: Docker detected. Postinstallation tasks not required. Continuing.
Processing triggers for libc-bin (2.31-0ubuntu9.1) ...
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Stopping Plex Media Server.
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svwait: fatal: timed out
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
I ended up going with https://forums.unraid.net/topic/40463-support-linuxserverio-plex-media-server and it is working fine.
