Issue HDR tone mapping with Alder Lake
Server Version#: 1.40.2.8395
Player Version#: IOS and other
Hello everybody. I have a problem with my server. I recently moved from a NUC i5-10210u to a Beelink N100.
Everything is installed on Proxmox with an LXC container on Debian.
Previously I could transcode everything without problem. Since I upgraded to N100. 4K hardware transcoding does not work if the HDR mapping tone option is enabled. Do you have any idea of ​​the problem ?
Plex log error :
more "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log" | grep ERROR
Apr 29, 2024 03:00:13.082 [124646515026744] ERROR - [Req#217/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] [AVHWDeviceContext @ 0x7ecec90f73c0] Failed to get number of OpenCL platforms: -1001.
Apr 29, 2024 03:00:13.083 [124646590524216] ERROR - [Req#220/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] [AVHWDeviceContext @ 0x7ecec90f73c0] Failed to get number of OpenCL platforms: -1001.
Apr 29, 2024 03:00:13.083 [124646544386872] ERROR - [Req#221/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] [Parsed_hwmap_2 @ 0x7ececa1f0c80] Failed to created derived device context: -19.
Apr 29, 2024 03:00:13.083 [124646577941304] ERROR - [Req#222/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] [Parsed_hwmap_2 @ 0x7ececa1f0c80] Failed to configure output pad on Parsed_hwmap_2
Apr 29, 2024 03:00:13.084 [124646510832440] ERROR - [Req#223/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] Error reinitializing filters!
Apr 29, 2024 03:00:13.085 [124646531803960] ERROR - [Req#224/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] Failed to inject frame into filter network: No such device
Apr 29, 2024 03:00:13.085 [124646540192568] ERROR - [Req#225/Transcode/4E96091C-6AFF-4E63-9C5F-469D3265198A/f5dfc6e4-d64a-4375-a206-c11f83945928] Error while processing the decoded data for stream #0:0
Uname :
uname -r
6.8.4-2-pve
Driver :
ls -l /dev/dri
total 0
crw-rw-rw- 1 root root 226,   0 29 avril 02:59 card0
crw-rw-rw- 1 root root 226, 128 29 avril 02:59 renderD128
Plex log server :
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs# cd /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs
more Plex\ Media\ Server.log | grep dri
Apr 29, 2024 03:05:14.656 [131323802954552] INFO - Preemptively preparing driver imd for GPU Alder Lake-N [UHD Graphics]
Apr 29, 2024 03:05:14.657 [131323802954552] INFO - Preemptively preparing driver icr for GPU Alder Lake-N [UHD Graphics]
Apr 29, 2024 03:05:55.092 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.139 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.150 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.158 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.166 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.173 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.181 [131323689708344] DEBUG - [Req#c5/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.417 [131323702291256] INFO - [Req#fc/Transcode/E6C7EE71-7618-413C-9BB8-E2980A4D489A] Preparing driver icr for GPU Alder Lake-N [UHD Graphics]
Apr 29, 2024 03:05:55.417 [131323702291256] DEBUG - [Req#fc/Transcode/E6C7EE71-7618-413C-9BB8-E2980A4D489A] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (Alder Lake-N [UHD Graphics])
Apr 29, 2024 03:05:55.421 [131323702291256] INFO - [Req#fc/Transcode/E6C7EE71-7618-413C-9BB8-E2980A4D489A] Preparing driver imd for GPU Alder Lake-N [UHD Graphics]
Apr 29, 2024 03:05:55.422 [131323702291256] DEBUG - [Req#fc/Transcode/E6C7EE71-7618-413C-9BB8-E2980A4D489A/JobRunner] Job running: EAE_ROOT=/tmp/pms-dffc4ae7-3885-40b5-a034-af029ad0376a/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/ad47460-4673-linux-x86_64/' LIBVA_DRIVERS_PATH="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64" OCL_ICD_VENDORS="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/cl-icds-linux-x86_64" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx cl_cache_dir="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Shaders/icr-138-linux-x86_64/" "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -codec:1 eac3_eae -eae_prefix:1 E6C7EE71-7618-413C-9BB8-E2980A4D489A_ -analyzeduration 20000000 -probesize 20000000 -i "/srv/hdd/plex/series/Avatar - The Last Airbender (2024) [tvdb-385925]/Saison 01/Avatar.The.Last.Airbender.2024.S01E01.MULTi.HDR.2160p.WEB.H265-FW.mkv" -filter_complex "[0:0]hwupload[0];[0]scale_vaapi=w=3840:h=2160:format=p010[1];[1]hwmap=derive_device=opencl[2];[2]tonemap_opencl=tonemap=mobius:format=nv12:m=bt709:p=bt709:r=tv[3];[3]hwmap=derive_device=vaapi:reverse=1[4];[4]hwupload[5]" -map "[5]" -codec:0 h264_vaapi -b:0 21301k -maxrate:0 28402k -bufsize:0 56804k -r:0 24 -force_key_frames:0 "expr:gte(t,n_forced*1)" -filter_complex "[0:1] aresample=async=1:ochl='stereo':rematrix_maxval=0.000000dB:osr=48000[6]" -map "[6]" -metadata:s:1 language=fra -codec:1 libopus -b:1 106k -segment_format matroska -f ssegment -individual_header_trailer 0 -flags +global_header -segment_header_filename header -segment_time 1 -segment_start_number 0 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/E6C7EE71-7618-413C-9BB8-E2980A4D489A/cd255641-3b3a-49f3-8127-e2763de52450/manifest?X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -segment_format_options output_ts_offset=10 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata:g -1 -map_metadata:c -1 -map_chapters -1 "media-%05d.ts" -start_at_zero -copyts -vsync cfr -init_hw_device vaapi=vaapi:/dev/dri/renderD128,driver=iHD -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/E6C7EE71-7618-413C-9BB8-E2980A4D489A/cd255641-3b3a-49f3-8127-e2763de52450/progress
Apr 29, 2024 03:05:55.588 [131323802954552] DEBUG - [JobRunner] Job running: EAE_ROOT=/tmp/pms-dffc4ae7-3885-40b5-a034-af029ad0376a/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/ad47460-4673-linux-x86_64/' LIBVA_DRIVERS_PATH="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/va-dri-linux-x86_64" X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -codec:1 eac3_eae -eae_prefix:1 E6C7EE71-7618-413C-9BB8-E2980A4D489A_ -analyzeduration 20000000 -probesize 20000000 -i "/srv/hdd/plex/series/Avatar - The Last Airbender (2024) [tvdb-385925]/Saison 01/Avatar.The.Last.Airbender.2024.S01E01.MULTi.HDR.2160p.WEB.H265-FW.mkv" -filter_complex "[0:0]scale=w=3840:h=2160:force_divisible_by=4[0];[0]format=p010,tonemap=mobius[1];[1]format=pix_fmts=yuv420p|nv12[2]" -map "[2]" -codec:0 libx264 -crf:0 24 -maxrate:0 28402k -bufsize:0 56804k -r:0 24 -preset:0 veryfast -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames:0 "expr:gte(t,n_forced*1)" -filter_complex "[0:1] aresample=async=1:ochl='stereo':rematrix_maxval=0.000000dB:osr=48000[3]" -map "[3]" -metadata:s:1 language=fra -codec:1 libopus -b:1 106k -segment_format matroska -f ssegment -individual_header_trailer 0 -flags +global_header -segment_header_filename header -segment_time 1 -segment_start_number 0 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/E6C7EE71-7618-413C-9BB8-E2980A4D489A/cd255641-3b3a-49f3-8127-e2763de52450/manifest?X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -segment_format_options output_ts_offset=10 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata:g -1 -map_metadata:c -1 -map_chapters -1 "media-%05d.ts" -start_at_zero -copyts -vsync cfr -init_hw_device vaapi=vaapi: -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/E6C7EE71-7618-413C-9BB8-E2980A4D489A/cd255641-3b3a-49f3-8127-e2763de52450/progress
Any ideas how to fix this ?
There are problems with the 6.8 kernel.
Back down to 6.5.
