I am having issues playing some BluRay rips on my PS4 Plex client, and was looking for some advice.
The server is a local server running on Unraid Pro. it is running in a needo/plex:latest docker on a dedicated SSD and everything is fully up to date. The server never seems stressed with CPU, RAM, LAN, and I/O all being well below 50% at all times.
The issues I am having are distortions and tearing that happen at random times, but seem to happen more when there is a lot of action on screen. I have re-ripped and even bought new media thinking that it might have been a bad BluRay. I have tried every setting I could think of to no avail.
My network is all Gig Lan, Netgear switches, Cat 6 Shielded Cables with dedicated IP’s on everything.
The server hardware is:
OS: Unraid 6.19
Docker: needo/plex:latest
Plex: 1.0.3.2461
CPU: AMD FX-8320E Eight-Core @ 3200
M/B: MSI - 970 GAMING
RAM: 8GB DDR3
An example movie is:
! General
! Unique ID : 99544602593708321803157171335630634489 (0x4AE397D4FDB35B6AB5ED9CB29E6F3DF9)
! Complete name : \x.x.x.x\Movies\Jupiter Ascending\Jupiter Ascending.mkv
! Format : Matroska
! Format version : Version 2
! File size : 28.9 GiB
! Duration : 2h 7mn
! Overall bit rate mode : Variable
! Overall bit rate : 32.4 Mbps
! Movie name : Jupiter Ascending
! Encoded date : UTC 2016-07-25 20:23:21
! Writing application : MakeMKV v1.9.10 win(x64-release)
! Writing library : libmakemkv v1.9.10 (1.3.3/1.4.4) win(x64-release)
! Original source medium : Blu-ray
! Cover : Yes
! Attachments : cover.jpg
! Video
! ID : 1
! ID in the original source m : 4113 (0x1011)
! Format : AVC
! Format/Info : Advanced Video Codec
! Format profile : High@L4.1
! Format settings, CABAC : Yes
! Format settings, ReFrames : 2 frames
! Format settings, GOP : M=1, N=10
! Codec ID : V_MPEG4/ISO/AVC
! Duration : 2h 7mn
! Bit rate mode : Variable
! Bit rate : 24.6 Mbps
! Width : 1 920 pixels
! Height : 1 080 pixels
! Display aspect ratio : 16:9
! Frame rate mode : Constant
! Frame rate : 23.976 (24000/1001) fps
! Color space : YUV
! Chroma subsampling : 4:2:0
! Bit depth : 8 bits
! Scan type : Progressive
! Bits/(Pixel*Frame) : 0.495
! Stream size : 21.9 GiB (76%)
! Language : English
! Default : No
! Forced : No
! Audio #1
! ID : 2
! ID in the original source m : 4352 (0x1100)
! Format : Atmos / TrueHD
! Codec ID : A_TRUEHD
! Duration : 2h 7mn
! Bit rate : 5 484 Kbps
! Maximum bit rate : 8 955 Kbps
! Channel(s) : Object Based / 8 channels
! Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
! Sampling rate : / 48.0 KHz
! Frame rate : 1 200.000 fps (40 spf)
! Bit depth : 24 bits
! Compression mode : Lossless
! Stream size : 4.89 GiB (17%)
! Title : Surround 7.1
! Default : Yes
! Forced : No
! Audio #2
! ID : 3
! Format : AC-3
! Format/Info : Audio Coding 3
! Mode extension : CM (complete main)
! Format settings, Endianness : Big
! Codec ID : A_AC3
! Duration : 2h 7mn
! Bit rate mode : Constant
! Bit rate : 384 Kbps
! Channel(s) : 6 channels
! Channel positions : Front: L C R, Side: L R, LFE
! Sampling rate : 48.0 KHz
! Frame rate : 31.250 fps (1536 spf)
! Compression mode : Lossy
! Stream size : 350 MiB (1%)
! Title : Surround 5.1
! Default : No
! Forced : No
! Audio #3
! ID : 4
! ID in the original source m : 4353 (0x1101)
! Format : AC-3
! Codec ID : A_AC3
! Duration : 2h 7mn
! Bit rate : 448 Kbps
! Stream size : 409 MiB (1%)
! Default : No
! Forced : No
! Audio #4
! ID : 5
! ID in the original source m : 4354 (0x1102)
! Format : AC-3
! Codec ID : A_AC3
! Duration : 2h 7mn
! Language : French
! Default : No
! Forced : No
! Audio #5
! ID : 6
! ID in the original source m : 4355 (0x1103)
! Format : AC-3
! Codec ID : A_AC3
! Duration : 2h 7mn
! Language : Spanish
! Default : No
! Forced : No
! Audio #6
! ID : 7
! ID in the original source m : 4356 (0x1104)
! Format : AC-3
! Codec ID : A_AC3
! Duration : 2h 7mn
! Language : Portuguese
! Default : No
! Forced : No
! Text #1
! ID : 8
! ID in the original source m : 4608 (0x1200)
! Format : PGS
! Codec ID : S_HDMV/PGS
! Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
! Duration : 2h 6mn
! Bit rate : 29.8 Kbps
! Count of elements : 3180
! Stream size : 27.1 MiB (0%)
! Default : No
! Forced : No
! Text #2
! ID : 10
! ID in the original source m : 4609 (0x1201)
! Format : PGS
! Duration : 2h 6mn
! Bit rate : 23.5 Kbps
! Count of elements : 2858
! Stream size : 21.3 MiB (0%)
! Language : French
! Default : No
! Forced : No
! Text #3
! ID : 12
! ID in the original source m : 4610 (0x1202)
! Format : PGS
! Duration : 2h 6mn
! Bit rate : 28.5 Kbps
! Count of elements : 3030
! Stream size : 25.9 MiB (0%)
! Default : No
! Forced : No
! Text #4
! ID : 14
! ID in the original source m : 4611 (0x1203)
! Format : PGS
! Duration : 2h 6mn
! Bit rate : 27.5 Kbps
! Count of elements : 3006
! Stream size : 25.0 MiB (0%)
! Default : No
! Forced : No
! Text #5
! ID : 16
! ID in the original source m : 4612 (0x1204)
! Format : PGS
! Duration : 2h 6mn
! Bit rate : 430 bps
! Count of elements : 66
! Stream size : 399 KiB (0%)
! Language : French
! Default : No
! Forced : No
! Text #6
! ID : 18
! ID in the original source m : 4613 (0x1205)
! Format : PGS
! Duration : 2h 6mn
! Bit rate : 382 bps
! Count of elements : 54
! Stream size : 354 KiB (0%)
! Default : No
! Forced : No
! Text #7
! ID : 20
! ID in the original source m : 4614 (0x1206)
! Format : PGS
! Duration : 2h 6mn
! Bit rate : 380 bps
! Stream size : 352 KiB (0%)
! Default : No
! Forced : No
! Menu
! 00:00:00.000 : en:Chapter 01
! 00:08:44.857 : en:Chapter 02
! 00:19:31.128 : en:Chapter 03
! 00:31:32.891 : en:Chapter 04
! 00:41:42.166 : en:Chapter 05
! 00:49:35.347 : en:Chapter 06
! 00:58:29.547 : en:Chapter 07
! 01:09:19.989 : en:Chapter 08
! 01:19:06.992 : en:Chapter 09
! 01:29:09.052 : en:Chapter 10
! 01:36:08.512 : en:Chapter 11
! 01:43:26.575 : en:Chapter 12
! 01:52:58.688 : en:Chapter 13
! 01:57:59.238 : en:Chapter 14
