Server Version#: Version 1.25.6.5577
Player Version#: Kodi app on TV, iPhone, Ipad
I just upgraded to DSM 7 and installed the latest Plex Server (manual installation via package center)
I used to be able to create a certificate using the current certificate I have running for the NAS.
You export the certificate, thereby receiving a private key, cert and chain file.
With this command: https://gist.github.com/churro-s/fa3fdeb5cf10ebb251aa88338b8b37db
sudo openssl pkcs12 -export -out ~/certificate.pfx \
-inkey /etc/letsencrypt/live/myhostname.no-ip.org/privkey.pem \
-in /etc/letsencrypt/live/myhostname.no-ip.org/cert.pem \
-certfile /etc/letsencrypt/live/myhostname.no-ip.org/chain.pem
You can create a .pfx file, then all you had to do was upload it to the NAS server and enter the details in Plex, see images
But the Plex server doesn’t seem to be validating the SSL anymore.
For some reason the common name is complete unrelated to my server url:
How can I add a PFX file correctly so my Plex is under https again?
