Issue (video stuttering) when playing HEVC content on MacOS
Server Version#: 1.40.4.8679
Player Version#: 4.133.0
Server is running from a docker container on a local Ubuntu machine.
Hello,
I’m having the following issue when streaming HEVC files from my server on MacOS.
This is what I see:
Browser doesn’t seem to matter (issue present on Edge, Chrome and Safari) and it doesn’t seem present on iPad or LG TV.
These are the file characteristics:
Bitrate 2000 kbps
Bit Depth 10
Chroma Location left
Chroma Subsampling 4:2:0
Codec ID hev1
Coded Height 1080
Coded Width 1792
Color Range tv
Frame Rate 24 fps
Height 1080
Level 4.0
Profile main 10
Ref Frames 1
Stream Identifier 1
Width 1792
Display Title 1080p (HEVC Main 10)
Extended Display Title 1080p (HEVC Main 10)
What could be causing this?
I can provide further logs or information if needed.
Thank you.
Do you experience the same if using the native Plex app (Plex for Mac or Plex HTPC) instead of the browser? Browsers are quite limited when it comes to media playback.
No issue using the Player app. But I don’t understand why it would happen on browser.
I would guess the browser can’t deal with some aspect of the video and asks the server to provide an optimized version, requiring the server to transcode the video, audio or burn-in subtitles.
Over the last few years, browsers got some improvements with regards to their video playback capabilities. But those are usually only focusing on very specific codecs / bitrates / … usually what you’ll see with online streamers who use highly optimized material. Browsers are by no means media playback devices that’ll deal with everything you throw at them.
What information is showing in the “now playing” tile for that playback on the Plex server dashboard or the Plex Dash app while your browser is streaming the video? The dashboard should show if there’s some transcoding and what parts of the stream are being transcoded.
Exemplary screenshot from the "now playing" section
https://support.plex.tv/articles/200871837-status-and-dashboard/
Edit: if you have a native player at hand, that’ll always give you a better playback experience. While that’s not answering your question why the playback in the web app might have some trouble, using the native app should make the browser obsolete to stream your Plex content.
The Dashboard is showing everything as “Direct Play”, issue is also present without subtitles.
