Issue with DNS shuting down...
  • ATV: ATV3 and firmware 6.0.2
  • The DNS server set on the ATV : 192.168.2.60
  • PlexConnect is installed on:  iMac 27in Late 2009 i7 2.8Ghz , OS X Mavericks (10.9 Build 13A603)
  • The local IP address of the device that PlexConnect is installed on: 192.168.2.60
  • the Plex media server (PMS) is installed on: iMac 27in Late 2009 i7 2.8Ghz , OS X Mavericks (10.9 Build 13A603)
  • The Plex media server (PMS) version number: 0.9.8.13.235-a263b7e
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.2.60
  • The PlexConnect version number.  did the Git Clone on 2013-11-15 at 15h15 (I had the error before, so to make sure I reinstalled from Git).
  • The content of your 'Settings.cfg' :
[PlexConnect]
enable_webserver_ssl = True
logpath = .
enable_dnsserver = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
  • detailed description of the issue (the clearer you can make this the better):
When starting the PlexConnect, it launch everything as normal, then after some DNS requests, it seems to crash the DNS.  The rest of PlexConnect is still running.  I have to do Ctrl+C to stop it and relaunch it :
15:15:22 DNSServer: Shutting down.
Process Process-1:
Traceback (most recent call last):
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
    self.run()
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/multiprocessing/process.py", line 114, in run
    self._target(*self._args, **self._kwargs)
  File "/Users/pducharme/Downloads/PlexConnect/DNSServer.py", line 375, in Run
    domain = DNSToHost(data, 12)
  File "/Users/pducharme/Downloads/PlexConnect/DNSServer.py", line 104, in DNSToHost
    Host = Host + DNSToHost(DNSdata, ((ord(DNSdata*) & 0x3F)<<8) + ord(DNSdata[i+1]) , True)+'.'
  File "/Users/pducharme/Downloads/PlexConnect/DNSServer.py", line 100, in DNSToHost
    while DNSdata*!='\0':
IndexError: string index out of range
I did not include the LOG because that error is not even in it !  I copy-paste it from the terminal...
I think i'm under some attack !!  I don't understand as my router doesn't let IN DNS request... but Source IP seems to be russian !!
15:26:09 DNSServer: DNS request received!
15:26:09 DNSServer: Source: ('79.134.44.1', 22668)
15:26:09 DNSServer: Domain: cheatsharez.com
15:26:09 DNSServer: ***forward request
15:26:19 DNSServer: DNS request received!
15:26:19 DNSServer: Source: ('79.134.44.1', 22494)
15:26:19 DNSServer: Domain: cheatsharez.com
15:26:19 DNSServer: ***forward request
15:26:28 DNSServer: DNS request received!
15:26:28 DNSServer: Source: ('79.134.44.1', 38255)
15:26:28 DNSServer: Domain: cheatsharez.com
15:26:28 DNSServer: ***forward request
15:26:38 DNSServer: DNS request received!
15:26:38 DNSServer: Source: ('79.134.44.1', 32308)
15:26:38 DNSServer: Domain: cheatsharez.com
15:26:38 DNSServer: ***forward request
15:26:47 DNSServer: DNS request received!
15:26:47 DNSServer: Source: ('79.134.44.1', 25134)
15:26:47 DNSServer: Domain: cheatsharez.com
15:26:47 DNSServer: ***forward request
15:26:57 DNSServer: DNS request received!
15:26:57 DNSServer: Source: ('79.134.44.1', 33336)
15:26:57 DNSServer: Domain: cheatsharez.com
15:26:57 DNSServer: ***forward request
15:26:57 DNSServer: -> DNS response from higher level
15:27:06 DNSServer: DNS request received!
15:27:06 DNSServer: Source: ('79.134.44.1', 39375)
15:27:06 DNSServer: Domain: cheatsharez.com
15:27:06 DNSServer: ***forward request
15:27:16 DNSServer: DNS request received!
15:27:16 DNSServer: Source: ('79.134.44.1', 30158)
15:27:16 DNSServer: Domain: cheatsharez.com
15:27:16 DNSServer: ***forward request
15:27:25 DNSServer: DNS request received!
15:27:25 DNSServer: Source: ('79.134.44.1', 28735)
15:27:25 DNSServer: Domain: cheatsharez.com
15:27:25 DNSServer: ***forward request
15:27:35 DNSServer: DNS request received!
15:27:35 DNSServer: Source: ('79.134.44.1', 37244)
15:27:35 DNSServer: Domain: cheatsharez.com
15:27:35 DNSServer: ***forward request
15:27:44 DNSServer: DNS request received!
15:27:44 DNSServer: Source: ('79.134.44.1', 21826)
15:27:44 DNSServer: Domain: cheatsharez.com
15:27:44 DNSServer: ***forward request
15:27:44 DNSServer: -> DNS response from higher level
15:27:53 DNSServer: DNS request received!
15:27:53 DNSServer: Source: ('79.134.44.1', 24970)
15:27:53 DNSServer: Domain: cheatsharez.com
15:27:53 DNSServer: ***forward request
15:27:54 DNSServer: -> DNS response from higher level
15:28:03 DNSServer: DNS request received!
15:28:03 DNSServer: Source: ('79.134.44.1', 26879)
15:28:03 DNSServer: Domain: cheatsharez.com
15:28:03 DNSServer: ***forward request
15:28:12 DNSServer: DNS request received!
15:28:12 DNSServer: Source: ('79.134.44.1', 38260)
15:28:12 DNSServer: Domain: cheatsharez.com
15:28:12 DNSServer: ***forward request
15:28:22 DNSServer: DNS request received!
15:28:22 DNSServer: Source: ('79.134.44.1', 27314)
15:28:22 DNSServer: Domain: cheatsharez.com
15:28:22 DNSServer: ***forward request
15:28:31 DNSServer: DNS request received!
15:28:31 DNSServer: Source: ('79.134.44.1', 34639)
15:28:31 DNSServer: Domain: cheatsharez.com
15:28:31 DNSServer: ***forward request
15:28:41 DNSServer: DNS request received!
15:28:41 DNSServer: Source: ('79.134.44.1', 23562)
15:28:41 DNSServer: Domain: cheatsharez.com
15:28:41 DNSServer: ***forward request
15:28:50 DNSServer: DNS request received!
15:28:50 DNSServer: Source: ('79.134.44.1', 35637)
15:28:50 DNSServer: Domain: cheatsharez.com
15:28:50 DNSServer: ***forward request
15:29:00 DNSServer: DNS request received!
15:29:00 DNSServer: Source: ('79.134.44.1', 31982)
15:29:00 DNSServer: Domain: cheatsharez.com
15:29:00 DNSServer: ***forward request
15:29:09 DNSServer: DNS request received!
15:29:09 DNSServer: Source: ('79.134.44.1', 23905)
15:29:09 DNSServer: Domain: cheatsharez.com
15:29:09 DNSServer: ***forward request
15:29:10 DNSServer: -> DNS response from higher level
15:29:19 DNSServer: DNS request received!
15:29:19 DNSServer: Source: ('79.134.44.1', 30939)
15:29:19 DNSServer: Domain: cheatsharez.com
15:29:19 DNSServer: ***forward request
15:29:28 DNSServer: DNS request received!
15:29:28 DNSServer: Source: ('79.134.44.1', 20121)
15:29:28 DNSServer: Domain: cheatsharez.com
15:29:28 DNSServer: ***forward request
15:29:38 DNSServer: DNS request received!
15:29:38 DNSServer: Source: ('79.134.44.1', 24666)
15:29:38 DNSServer: Domain: cheatsharez.com
15:29:38 DNSServer: ***forward request
15:29:47 DNSServer: DNS request received!
15:29:47 DNSServer: Source: ('79.134.44.1', 37008)
15:29:47 DNSServer: Domain: cheatsharez.com
15:29:47 DNSServer: ***forward request
15:29:57 DNSServer: DNS request received!
15:29:57 DNSServer: Source: ('79.134.44.1', 33575)
15:29:57 DNSServer: Domain: cheatsharez.com
15:29:57 DNSServer: ***forward request
15:30:06 DNSServer: DNS request received!
15:30:06 DNSServer: Source: ('79.134.44.1', 35512)
15:30:06 DNSServer: Domain: cheatsharez.com
15:30:06 DNSServer: ***forward request
15:30:16 DNSServer: DNS request received!
15:30:16 DNSServer: Source: ('79.134.44.1', 27846)
15:30:16 DNSServer: Domain: cheatsharez.com
15:30:16 DNSServer: ***forward request
15:30:25 DNSServer: DNS request received!
15:30:25 DNSServer: Source: ('79.134.44.1', 22079)
15:30:25 DNSServer: Domain: cheatsharez.com
15:30:25 DNSServer: ***forward request
15:30:35 DNSServer: DNS request received!
15:30:35 DNSServer: Source: ('79.134.44.1', 21975)
15:30:35 DNSServer: Domain: cheatsharez.com
15:30:35 DNSServer: ***forward request
15:30:54 DNSServer: DNS request received!
15:30:54 DNSServer: Source: ('79.134.44.1', 38867)
15:30:54 DNSServer: Domain: cheatsharez.com
15:30:54 DNSServer: ***forward request
15:31:03 DNSServer: DNS request received!
15:31:03 DNSServer: Source: ('79.134.44.1', 22532)
15:31:03 DNSServer: Domain: cheatsharez.com
15:31:03 DNSServer: ***forward request
15:31:13 DNSServer: DNS request received!
15:31:13 DNSServer: Source: ('79.134.44.1', 27942)
15:31:13 DNSServer: Domain: cheatsharez.com
15:31:13 DNSServer: ***forward request
15:31:22 DNSServer: DNS request received!
15:31:22 DNSServer: Source: ('79.134.44.1', 33111)
15:31:22 DNSServer: Domain: cheatsharez.com
15:31:22 DNSServer: ***forward request
15:31:32 DNSServer: DNS request received!
15:31:32 DNSServer: Source: ('79.134.44.1', 27123)
15:31:32 DNSServer: Domain: cheatsharez.com
15:31:32 DNSServer: ***forward request
15:31:32 DNSServer: -> DNS response from higher level
15:31:41 DNSServer: DNS request received!
15:31:41 DNSServer: Source: ('79.134.44.1', 25988)
15:31:41 DNSServer: Domain: cheatsharez.com
15:31:41 DNSServer: ***forward request
15:32:00 DNSServer: DNS request received!
15:32:00 DNSServer: Source: ('79.134.44.1', 27821)
15:32:00 DNSServer: Domain: cheatsharez.com
15:32:00 DNSServer: ***forward request
15:32:10 DNSServer: DNS request received!
15:32:10 DNSServer: Source: ('79.134.44.1', 35347)
15:32:10 DNSServer: Domain: cheatsharez.com
15:32:10 DNSServer: ***forward request
15:32:19 DNSServer: DNS request received!
15:32:19 DNSServer: Source: ('79.134.44.1', 21885)
15:32:19 DNSServer: Domain: cheatsharez.com
15:32:19 DNSServer: ***forward request
15:32:19 DNSServer: -> DNS response from higher level
15:32:29 DNSServer: DNS request received!
15:32:29 DNSServer: Source: ('79.134.44.1', 25310)
15:32:29 DNSServer: Domain: cheatsharez.com
15:32:29 DNSServer: ***forward request
15:32:38 DNSServer: DNS request received!
15:32:38 DNSServer: Source: ('79.134.44.1', 25277)
15:32:38 DNSServer: Domain: cheatsharez.com
15:32:38 DNSServer: ***forward request
15:32:48 DNSServer: DNS request received!
15:32:48 DNSServer: Source: ('79.134.44.1', 22123)
15:32:48 DNSServer: Domain: cheatsharez.com
15:32:48 DNSServer: ***forward request
15:32:48 DNSServer: -> DNS response from higher level
15:32:57 DNSServer: DNS request received!
15:32:57 DNSServer: Source: ('79.134.44.1', 25273)
15:32:57 DNSServer: Domain: cheatsharez.com
15:32:57 DNSServer: ***forward request
15:33:07 DNSServer: DNS request received!
15:33:07 DNSServer: Source: ('79.134.44.1', 27325)
15:33:07 DNSServer: Domain: cheatsharez.com
15:33:07 DNSServer: ***forward request
15:33:16 DNSServer: DNS request received!
15:33:16 DNSServer: Source: ('79.134.44.1', 30554)
15:33:16 DNSServer: Domain: cheatsharez.com
15:33:16 DNSServer: ***forward request
15:33:26 DNSServer: DNS request received!
15:33:26 DNSServer: Source: ('79.134.44.1', 25016)
15:33:26 DNSServer: Domain: cheatsharez.com
15:33:26 DNSServer: ***forward request
15:33:35 DNSServer: DNS request received!
15:33:35 DNSServer: Source: ('79.134.44.1', 38021)
15:33:35 DNSServer: Domain: cheatsharez.com
15:33:35 DNSServer: ***forward request
15:33:45 DNSServer: DNS request received!
15:33:45 DNSServer: Source: ('79.134.44.1', 21391)
15:33:45 DNSServer: Domain: cheatsharez.com
15:33:45 DNSServer: ***forward request
15:33:54 DNSServer: DNS request received!
15:33:54 DNSServer: Source: ('79.134.44.1', 29832)
15:33:54 DNSServer: Domain: cheatsharez.com
15:33:54 DNSServer: ***forward request
15:34:04 DNSServer: DNS request received!
15:34:04 DNSServer: Source: ('79.134.44.1', 29036)
15:34:04 DNSServer: Domain: cheatsharez.com
15:34:04 DNSServer: ***forward request
15:34:13 DNSServer: DNS request received!
15:34:13 DNSServer: Source: ('79.134.44.1', 28082)
15:34:13 DNSServer: Domain: cheatsharez.com
15:34:13 DNSServer: ***forward request
15:34:23 DNSServer: DNS request received!
15:34:23 DNSServer: Source: ('79.134.44.1', 26314)
15:34:23 DNSServer: Domain: cheatsharez.com
15:34:23 DNSServer: ***forward request
15:34:32 DNSServer: DNS request received!
15:34:32 DNSServer: Source: ('79.134.44.1', 28323)
15:34:32 DNSServer: Domain: cheatsharez.com
15:34:32 DNSServer: ***forward request
15:34:42 DNSServer: DNS request received!
15:34:42 DNSServer: Source: ('79.134.44.1', 39305)
15:34:42 DNSServer: Domain: cheatsharez.com
15:34:42 DNSServer: ***forward request
15:34:51 DNSServer: DNS request received!
15:34:51 DNSServer: Source: ('79.134.44.1', 32303)
15:34:51 DNSServer: Domain: cheatsharez.com
15:34:51 DNSServer: ***forward request
15:34:51 DNSServer: -> DNS response from higher level
15:35:01 DNSServer: DNS request received!
15:35:01 DNSServer: Source: ('79.134.44.1', 35756)
15:35:01 DNSServer: Domain: cheatsharez.com
15:35:01 DNSServer: ***forward request
15:35:10 DNSServer: DNS request received!
15:35:10 DNSServer: Source: ('79.134.44.1', 22858)
15:35:10 DNSServer: Domain: cheatsharez.com
15:35:10 DNSServer: ***forward request
15:35:20 DNSServer: DNS request received!
15:35:20 DNSServer: Source: ('79.134.44.1', 28900)
15:35:20 DNSServer: Domain: cheatsharez.com
15:35:20 DNSServer: ***forward request
15:35:29 DNSServer: DNS request received!
15:35:29 DNSServer: Source: ('79.134.44.1', 38273)
15:35:29 DNSServer: Domain: cheatsharez.com
15:35:29 DNSServer: ***forward request
15:35:39 DNSServer: DNS request received!
15:35:39 DNSServer: Source: ('79.134.44.1', 24270)
15:35:39 DNSServer: Domain: cheatsharez.com
15:35:39 DNSServer: ***forward request
15:35:48 DNSServer: DNS request received!
15:35:48 DNSServer: Source: ('79.134.44.1', 23363)
15:35:48 DNSServer: Domain: cheatsharez.com
15:35:48 DNSServer: ***forward request
15:35:58 DNSServer: DNS request received!
15:35:58 DNSServer: Source: ('79.134.44.1', 36402)
15:35:58 DNSServer: Domain: cheatsharez.com
15:35:58 DNSServer: ***forward request
15:36:07 DNSServer: DNS request received!
15:36:07 DNSServer: Source: ('79.134.44.1', 33632)
15:36:07 DNSServer: Domain: cheatsharez.com
15:36:07 DNSServer: ***forward request
15:36:17 DNSServer: DNS request received!
15:36:17 DNSServer: Source: ('79.134.44.1', 35062)
15:36:17 DNSServer: Domain: cheatsharez.com
15:36:17 DNSServer: ***forward request
15:36:26 DNSServer: DNS request received!
15:36:26 DNSServer: Source: ('79.134.44.1', 28482)
15:36:26 DNSServer: Domain: cheatsharez.com
15:36:26 DNSServer: ***forward request
15:36:26 DNSServer: -> DNS response from higher level
15:36:36 DNSServer: DNS request received!
15:36:36 DNSServer: Source: ('79.134.44.1', 31601)
15:36:36 DNSServer: Domain: cheatsharez.com
15:36:36 DNSServer: ***forward request
15:36:45 DNSServer: DNS request received!
15:36:45 DNSServer: Source: ('79.134.44.1', 30881)
15:36:45 DNSServer: Domain: cheatsharez.com
15:36:45 DNSServer: ***forward request
15:36:54 DNSServer: DNS request received!
15:36:54 DNSServer: Source: ('79.134.44.1', 34102)
15:36:54 DNSServer: Domain: cheatsharez.com
15:36:54 DNSServer: ***forward request
15:37:04 DNSServer: DNS request received!
15:37:04 DNSServer: Source: ('79.134.44.1', 25288)
15:37:04 DNSServer: Domain: cheatsharez.com
15:37:04 DNSServer: ***forward request
15:37:13 DNSServer: DNS request received!
15:37:13 DNSServer: Source: ('79.134.44.1', 21195)
15:37:13 DNSServer: Domain: cheatsharez.com
15:37:13 DNSServer: ***forward request
15:37:23 DNSServer: DNS request received!
15:37:23 DNSServer: Source: ('79.134.44.1', 29718)
15:37:23 DNSServer: Domain: cheatsharez.com
15:37:23 DNSServer: ***forward request
15:37:32 DNSServer: DNS request received!
15:37:32 DNSServer: Source: ('79.134.44.1', 21357)
15:37:32 DNSServer: Domain: cheatsharez.com
15:37:32 DNSServer: ***forward request
15:37:32 DNSServer: -> DNS response from higher level
15:37:42 DNSServer: DNS request received!
15:37:42 DNSServer: Source: ('79.134.44.1', 36131)
15:37:42 DNSServer: Domain: cheatsharez.com
15:37:42 DNSServer: ***forward request
15:37:51 DNSServer: DNS request received!
15:37:51 DNSServer: Source: ('79.134.44.1', 31118)
15:37:51 DNSServer: Domain: cheatsharez.com
15:37:51 DNSServer: ***forward request
15:38:01 DNSServer: DNS request received!
15:38:01 DNSServer: Source: ('79.134.44.1', 26187)
15:38:01 DNSServer: Domain: cheatsharez.com
15:38:01 DNSServer: ***forward request
15:38:10 DNSServer: DNS request received!
15:38:10 DNSServer: Source: ('79.134.44.1', 36752)
15:38:10 DNSServer: Domain: cheatsharez.com
15:38:10 DNSServer: ***forward request
15:38:20 DNSServer: DNS request received!
15:38:20 DNSServer: Source: ('79.134.44.1', 35952)
15:38:20 DNSServer: Domain: cheatsharez.com
15:38:20 DNSServer: ***forward request
15:38:29 DNSServer: DNS request received!
15:38:29 DNSServer: Source: ('79.134.44.1', 22836)
15:38:29 DNSServer: Domain: cheatsharez.com
15:38:29 DNSServer: ***forward request
15:38:39 DNSServer: DNS request received!
15:38:39 DNSServer: Source: ('79.134.44.1', 25980)
15:38:39 DNSServer: Domain: cheatsharez.com
15:38:39 DNSServer: ***forward request
15:38:48 DNSServer: DNS request received!
15:38:48 DNSServer: Source: ('79.134.44.1', 32918)
15:38:48 DNSServer: Domain: cheatsharez.com
15:38:48 DNSServer: ***forward request
15:38:58 DNSServer: DNS request received!
15:38:58 DNSServer: Source: ('79.134.44.1', 29621)
15:38:58 DNSServer: Domain: cheatsharez.com
15:38:58 DNSServer: ***forward request
15:39:08 DNSServer: DNS request received!
15:39:08 DNSServer: Source: ('79.134.44.1', 34597)
15:39:08 DNSServer: Domain: cheatsharez.com
15:39:08 DNSServer: ***forward request
15:39:17 DNSServer: DNS request received!
15:39:17 DNSServer: Source: ('79.134.44.1', 36062)
15:39:17 DNSServer: Domain: cheatsharez.com
15:39:17 DNSServer: ***forward request
15:39:26 DNSServer: DNS request received!
15:39:26 DNSServer: Source: ('79.134.44.1', 36492)
15:39:26 DNSServer: Domain: cheatsharez.com
15:39:26 DNSServer: ***forward request
15:39:36 DNSServer: DNS request received!
15:39:36 DNSServer: Source: ('79.134.44.1', 34189)
15:39:36 DNSServer: Domain: cheatsharez.com
15:39:36 DNSServer: ***forward request
15:39:45 DNSServer: DNS request received!
15:39:45 DNSServer: Source: ('79.134.44.1', 27186)
15:39:45 DNSServer: Domain: cheatsharez.com
15:39:45 DNSServer: ***forward request
15:39:55 DNSServer: DNS request received!
15:39:55 DNSServer: Source: ('79.134.44.1', 38485)
15:39:55 DNSServer: Domain: cheatsharez.com
15:39:55 DNSServer: ***forward request
15:40:05 DNSServer: DNS request received!
15:40:05 DNSServer: Source: ('79.134.44.1', 24522)
15:40:05 DNSServer: Domain: cheatsharez.com
15:40:05 DNSServer: ***forward request
15:40:14 DNSServer: DNS request received!
15:40:14 DNSServer: Source: ('79.134.44.1', 27292)
15:40:14 DNSServer: Domain: cheatsharez.com
15:40:14 DNSServer: ***forward request
15:40:14 DNSServer: -> DNS response from higher level
15:40:23 DNSServer: DNS request received!
15:40:23 DNSServer: Source: ('79.134.44.1', 26829)
15:40:23 DNSServer: Shutting down.
Process Process-1:
    self.run()
line 375... could you please extend this area with
    printDNSdata_raw(data)
to look like
if opcode == 0:                     # Standard query
. Please post the output when it crashes again...
Thanks!
Check your router as we’ll and make sure the device running PkexConnect is not in a DMZ.
I found Out it was DMZ ! I had 377 ports open on the computer!! I repaired that.
Sorry to resurrect this thread, but I am also having issues with DNS crashing; except in my case, the device running PkexConnect is not in a DMZ.
02:03:54 DNSServer: Source: ('192.168.69.98', 58116)
02:03:54 DNSServer: Shutting down.
Process Process-1:
  File "C:\Python27\lib\multiprocessing\process.py", line 258, in _bootstrap
    self.run()
  File "C:\Python27\lib\multiprocessing\process.py", line 114, in run
  File "C:\PlexConnect\DNSServer.py", line 375, in Run
  File "C:\PlexConnect\DNSServer.py", line 104, in DNSToHost
[i+1]) , True)+'.'
  File "C:\PlexConnect\DNSServer.py", line 100, in DNSToHost
