Issue with live lyrics and the new controls
First, thanks for fixing the live lyrics.
There’s a new issue, though. When I first click the music symbol to get the lyrics to appear, they appear, but I can’t scroll up and down to see the end of the lyrics. What I used to have to do was press right on the dpad to select the vertical scroll bar, and then down to scroll.
Right now, though, when I press right to select the scroll bar, it also is seen as a skip, so it skips 10 or 30 seconds forward.
I guess an easy fix would be to have the scroll bar auto selected when we first get to that screen.
Thanks again @KarlDag!
We will still need the horizontal actions for navigating in the case where there are multiple versions of lyrics and to allow toggling the auto-scroll functionality.
I’ve created a new bug report so we can get this fixed up.
Been fixed already, works great. Thanks a lot!
