Issue with no posslibe direct flay full quality with Nvidia shield
Server Version#:1.27.0.5889-6a2ff9c39
Player Version#: last from Google Store
Hi all, I never had any issue for playing a 4K hdr on my projector using Nvidia shield as my main player without the need to encode. but I got an issue with a hole tv show “Halo” that my shield is not capable to play without transcoding. As I want to see it in 4K HDR I don´t know how to do it. transcoding to HD it works but I lost a lot of quality. What can it be as the other multiple films or tv show with HDR etc always play at original quality without problems. this is the info from the file that is not capable to read it.
Media
  • Duration 47:57
  • Bitrate 14305 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Video Resolution 4K
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile main 10
Part
  • Duration 47:57
  • File halo.s01e08.hdr.2160p.web.h265-ggez.mkv
  • Size 4.79 GB
  • Container MKV
  • Codec HEVC
  • Bitrate 13536 kbps
  • Bit Depth 10
  • Chroma Location topleft
  • Chroma Subsampling 4:2:0
  • Coded Height 2160
  • Coded Width 3840
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.976 fps
  • Height 2160
  • Level 5.0
  • Profile main 10
  • Ref Frames 1
  • Width 3840
  • Display Title 4K HDR10 (HEVC Main 10)
  • Extended Display Title 4K HDR10 (HEVC Main 10)
  • Codec EAC3
  • Channels 6
  • Bitrate 768 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout 5.1(side)
  • Sampling Rate 48000 Hz
  • Display Title English (EAC3 5.1)
  • Extended Display Title English (EAC3 5.1)
  • Codec SRT
  • Language English
  • Language Tag en
  • Title English
  • Display Title English (SRT)
  • Extended Display Title English (SRT)
  • Codec SRT
  • Language English
  • Language Tag en
  • Title English [SDH]
  • Extended Display Title English [SDH] (SRT)
I tried to see the same fikle using my mcbok pro using the Plex player (last version) and it workl perfectly same happen with my ipad pro it can play at maximum quality withlut transcoding. Can someone help me to solve this?
thanks in advance!
During playback when you look at playback info in the app why does it say it is transcoding?
