Nvidia Shield Pro 2019, What codecs work without transcoding?
Server Version#: 1.25.2.5319
Player Version#: 8.28.2.29938
How can I tell what codecs I can play with Plex on my Nvidia Shield Pro without relying on the server doing transcoding?
For example “4K (HEVC Main 10 HDR)” seems to be triggering transcoding, and the server simply can’t keep up.
The shield will directly play just about anything you throw at it. I suspect there is another issue, look in the logs to see why it is transcoding.
I suggest looking at this forum post about 4k and PLEX.
There are many things that can trigger transcoding with 4k, so after going through that and making sure all your settings and your setup are good to handle 4k, then I would suggest looking at your logs.
-Shark2k
Thanks, ended up being the need to explicitly enable HDR on the Shield 2019 Pro
