I have a very large playlist that I’m trying to work with.
I’m add the files to the playlist
Go into the playlist
Newly added files are at the bottom
Have to drag files from the bottom to where I want them in the playlist and since it has a few hundred files it literally takes a minute or more just to drag it up the list to where I want it
Is there a way to re number a file in the playlist so it goes where I want it instead of manually dragging it?
The scrolling is pretty slow when dragging a file
I’m using Plex Media Server on a PC
Is there a better way to do this?
Thanks!
