First, I’m on the Beta update channel, using Plex version 1.13.9.5456 with a HDHomeRun Connect dual tuner, and the server is on a Windows 10 Pro machine. I also have a TiVo Roamio OTA that we are still using until we can better rely on the Plex DVR, but this also allows me to compare recordings that could technically be the same. Both the TiVo and the HDHomeRun are connected to the same antenna.
I’ve had a few recording issues over the past month or two.
In the ‘random glitchiness’ category: I had a show that recorded a little over a week ago that I had told the server to record a few hours in advance, but it didn’t start recording until a couple of minutes into the show. That apparently freaked the timecode out or something, because I have it set to automatically delete the commercials, and since the DVR didn’t recognize that the recording had started late, it was cutting out random chunk of show, I am assuming because it thought that was where the commercials were. This has only happened once to my knowledge.
The other issue is more consistent and frustrating. Locally, we have 2 channels that are supposed to air the CW network, 2.2 and 35.1 (both have the same call letters, KYUU, so don’t ask me why there are 2 and they are so wildly far apart). On our TiVo, we have both enabled because the TiVo says 35.1 is only an SD broadcast, but 2.2 often has a really low quality signal, so it usually records from 35.1. On the Plex DVR, I disabled 35.1 months ago because having both enabled seemed to confuse the DVR, especially since the 2 channels generally show the same shows at the same time.
This is where it gets weird.
So, both 2.2 and 35.1 say that the EXACT SAME episode of Supernatural shows at the same time (Thursdays at 7pm). Both describe the new one. The EPG data is the same. The TiVo records the show on 35.1 and the Plex DVR records the show on 2.2.
For the last month, without fail, the Plex DVR records some wildly wrong, many years old episode of the show. Every. Time. I cannot check the channel from which it was recorded because the Plex will not give me that information (that would be REALLY nice to have), but according to the time and date of the file, it was recorded at the correct time.
Now, you are probably thinking that the program data for 2.2 is just wrong, and that the Plex DVR records that because it thinks it is correct, though it turns out not to be. This would make more sense. Except it’s not the case. In trying to figure things out, I set the TiVo to record from BOTH channels (2.2 and 35.1) a couple of weeks ago, and both were the same episode (though of different qualities) BUT!! the episode recorded on 2.2 by the Plex DVR was TOTALLY DIFFERENT! Like, 10 years old!
I only tried that experiment once, but I set it up to do it again this week.
Honestly, it’s freaking me out. Not to mention being incredibly annoying. The nearest I can figure is that the Plex DVR is thinking it’s recording from 2.2, and has the EPG from 2.2, but is actually somehow tuned to some other channel that shows older episodes of Supernatural at the same time.
Help?
But it would be nice if the All Powerful Plex Coders could find the little bug in the server that gets confused when there are similar items in different folders (from different sources).
