Keep and Delete Episodes After Playing Not Available on New Recordings
Server Version#: 1.22.3.4392
Player Version#: 1.31.1.2262-74fdc6b7
Tuner Make/Model: HDHomeRun CONNECT
Guide/Lineup name: DVR—Local Broadcast Listings (6 channels)
Using XMLTV?: No
Channel number/Name: Not Applicable
The “Record Options” for my old programs shows “Keep” and “Delete Episodes After Playing” pull downs after the Detect Commercials pull down. And on the Calendar View of the DVR Schedule, all scheduled recordings set up previously show a little triangle with an exclamation point in it and the boxes are a red/brown color.
When I set up a new recording, however, the “Keep” and “Delete Episodes After PLaying” are not available and when I save the recording setup, the entry in the DVR Schedule shows with normal color and no little triangle.
I have a lifetime Plex Pass if that matters, however I’d like to be able to set the retention parameters for new recordings. Has this function been removed?
Thank you
