Excited to give this a go on my Pi! But when it boots up for me the keyboard doesn't want to work.
I tried re flashing the SD card and a different keyboard with no luck.
Anyone having the same problem?
Im having exactly the same problem. Can control it via the iOS app, but not with my usb keyboard
Please try an other Power supply or powered USB-Hub. Maybe the Keyboard just needs to much power…
See also: http://openelec.tv/forum/134-usage/39261-keyboard-mouse-not-responding
Please try an other Power supply or powered USB-Hub. Maybe the Keyboard just needs to much power...
Do you have anything else plugged in to USB? If you have the wrong Wifi dongle, it will chew up all USB b/w
Yeah, I got the same problem too. I tried with logitech wireless keyboard, usb logitech mouse and a wired usb logitech mouse and rasplex does not detect them. I am currently running from sd card only, so there is only one usb device connected to the usb ports.
I also tried using an external powered usb hub, and still same results.
Help?
My bad, my keyboard is broken....
