Keyboard Shortcut
F6 keyboard shortcut stopped working. Usually brings up media item title, poster, and description. Now just the progress bar appears. Have mapped to my Harmony remote, have reapplied, still doesn’t work. Not sure if this is an opht thing or skin thing. Not the end of the world, appreciate any response nonetheless. Cheers.
Beuller? Beuller?
Which skin?
Plex Black Edition
Set log to debug on OpenPHT. Reboot, press F6 and then post the log here for us to review. You should post your keyboard.xml, remote.xml, etc.
Key remapping are not at the skin level though. So either your SD card is corrupted, you changed something, or your harmony is messed up. We just need to figure out which it is.
Solved. Under skin settings/general there’s an option to hide poster/info from osd when play is paused. Unchecking this option seems to have solved the issue. Never was a problem before, but not gonna worry about it. Like the old Bud Light commercial, “why ask why?” As long as it works I’m good. Thanks for your help fellas.
