I want to add LastFM to the list of Agents that can scan movies.
You are probably asking why - so the quick answer is music clips.
I can’t seem to get them to scan properly using the available scanners.
First I wanted to ask if there is a clear instructions somewhere about writing scanners.
From what I’ve seen there are instructions for Plug-Ins but no scanner - I might have just missed something.
But from what I’ve looked at should I just add a method to the init.py file that has the “Agent.Movies” parameter and direct it to the artists or the albums method?
Also where should I change this in the PlexMediaServer package or under the library?
Any tips for a beginner would help.
Thanks…
