Latest Beta Plex Pass Transcoder Issues
and another one, from the channel I was attempting to watch before having to roll back, in case it matters
The logs included no or did you need verbose logging etc?
I showed logs from latest beta and install latest public which they work
I mean it’s a beta, there will be issues lol I’m not mad I just want to help make it better
Hopefully this build helps with some of the issues you guys are seeing on roklu and apple clients!
Desktop Platforms
NAS Devices
Chris if you look up I posted original logs with 1.43
Just some files fail transcodes and it’s not client specific also retested with the last public 1.42 which works
Second post on thread btw
The version he linked is a newer 1.43 than the beta version available right now. I can confirm if fixes the issues on Roku and appletv, at least for me it did.
When I originally created my thread my issue wasnt with clients, actually for me, all clients worked its just specific content, attached logs with the forum link you provided, oddly again, just certain movies, all works on plexmediaserver_1.42.2.10156-f737b826c_amd64.deb
Plex Media Server Logs_2025-09-27_06-16-11.zip (1.3 MB)
Yes was the same for me. 1.43 updated FFmpeg. The 1.43 build he linked above fixed the issues that the previous 1.43 introduced.
live tv stream still broken with new version, but only to Windows player - works fine playing on Android app (from March).
curling stream from satellite box always works, on remote pc and plex server pc
do you mean plex app for Windows or PMS in Browser?
PMP Windows app
When trying to play, check the detailed activity in pms. It will transcoding if the stream is interlaced.Audio that is mp2 is the same. Try turning off hardware transcoding.
makes no difference.
also broken playing in browser on same client pc.
This is how I have it set up.
same, and every other variation.
I’m rolling back again, now
Ye si tested it and posted logs I never have client issues it was specific to certain content that works on latest 1.42
@techieanalyst logs can only say so much, for your particular issues i will need samples of the “bad” files that reproduce the issues.
