Lets get a new metadata field for beats per minute (BPM)
I would really love to have a field to enter in the BPM for songs so that you can keep the same speeds for playlists.
better yet, have a plugin to https://songbpm.com/ which tells you that info.
This would be epic for people trying to put together playlists for workouts, road trips…to keep the same music speeds, or go 1/2 speeds or 2x speeds. you get the point.
There’s already an existing suggestion discussing an option to add bpm to the metadata within Plex and use it to create smart playlists etc. I suggest you comment/vote in that thread in order to help us avoid distracting or cannibalizing votes. Unless I’m missing some unique aspect of your suggestion I’ll close this thread as a duplicate.
I must of missed it in my search before submitting this one. I’ll check it out. thanks!
