Let's talk subtitles
I have a movie called …
A:\movies\ABC\ABC.1080p.BluRay.1600MB.DD2.0.x264.mkv
… and a matching subtitle called …
A:\movies\ABC\ABC.1080p.BluRay.1600MB.DD2.0.x264.srt
:slight_smile: When I play the movie on my the server PC, the subtitles appear.
:slight_smile: When I play the movie on my phone’s Plex app, the subtitles appear.
:rage: When I play the movie on my Sony Bravia, the subtitles do not appear.
:slight_smile: When I play other movies on my Sony Bravia, the subtitles appear.
:rage: When I try to cast from the Plex app on my phone to the Sony Bravia, I get “Sorry, something went wrong”. I’ll save that for another topic.
:rage: When I try to cast from the the web-version of Plex on my phone to the Sony Bravia, it hangs for 10-20 minutes before I have to stop it. I’ll save that for another topic.
Plex Server version number?
Client App version numbers?
Pull Plex Server Logs after problem is recreated and post the full .zip file here.
Plex Media Server Logs_2024-12-24_11-48-15.zip (6.1 MB)
Server: 1.41.3.9314-a0bfb8370
Client: 10.24.1.2319 (d613f885)
FYI: Logs are from February. Did you forget to tell me to enable logging or something? I can’t remember how to do that.
Anything? Why are subtitles being blocked for just this one movie and just on this one device? I tried using ffmpeg to embed the subtitles. That worked as they are now selectable directly but … they still do not appear and only for the living room TV. Subtitles work on the server, my phone, the TV in the bedroom … but not the TV in the living room. Subtitles work in the living room for other movies but just not this one!!!
Have you run analyse on that Library via PMS before trying to watch TV?
Personally I use MKVToolNIx to flag subs and naming Subs correctly.
Example for forced: en.forced. (Works for me)
After Multiplexing complete and you have corrected the file name by removing (1) but before secure old file somewhere else in case. Put the corrected file in your Movie library
Run Empty Trash, Then run Analyse in PMS as attached.
https://support.plex.tv/articles/200471133-adding-local-subtitles-to-your-media/
I’m sure that MKVToolNIx is a fine product but I’d like to get to the bottom of why:
:grinning: Subtitles for “It’s a Wonderful Life” work on other TVs (like Vizio or Samsung).
:grinning: Subtitles for other movies (like “Home Alone”) work on “SONY Bravia TV”
:rage: Subtitles for “It’s a Wonderful Life” DO NOT WORK on “SONY Bravia TV”.
Ok, labling the subs correctly allows all clients to work as intended. The correct subs when required. Works for me
That’s great that it works for you and “Works for me” is actually the most popular forum phrase. Unfortunately, “Works for me” is not very help to the people it doesn’t work for.
My subs were named properly and they are now embedded. Embedded subs changed nothing as the subs work … either way … on all TVs except “SONY BRAVIA”?
When you are playing a movie on the Bravia and turn on the subtitles, when they don’t show up on screen is the Dashboard on the server indicating it’s displaying them?
Also, this may be be nothing, but do the subtitles that DO work on the Bravia have a language code in the file name? What you shared as an example isn’t the correct naming convention - but I know that you just used an example file name, so maybe you hand typed it and just omitted the language code. “ABC (2018).en.srt” would be the correct format. Maybe the Bravia app itself has an issue that it can’t detect “almost” correct file names that other apps are able to?
No disrespect intended, because you did state the file names were correct, but the example you gave was not correct. Like I said above, maybe your file names ARE correct and I’m way off base! But it can’t hurt to rename the movie and .srt files as above as an experiment.
Remember, this movie’s subtitles display on two other TVs in the house (Samsung and Vizio), three cell phones, and, of course the server. Subtitles do NOT display on the Sony but other movies do.
Here is how the dashboard looks when the movie is playing on the Vizio:
Notice is says “Direct Play” underneath! Why is that different?
All of the TV’s, server, and cell phones are all on the same network?
The Vizio is remote playing and the Sony has an indirect connection. The indirect connection causes the file to be run through a Plex relay.
If everything is on the same network and your getting remote and indirect play that sounds like a (maybe the) problem to me.
Do you mean all that “subnet” B.S.? I thought I addressed that months ago with some server settings.
Why do we need to “know” these specific nitty gritty things? Of course they are all on the same network … it’s my home. The Sony is connected to the router via ethernet but the Plex Server PC and the Vizio TV are connected via wi-fi to the same router.
WTF is your problem. He’s just helping you troubleshoot.
The problem is probably in the subtitle file. Open the file in a text editor or open it in Subtitle Edit, then save again; make sure to save without BOM. Rescan and refresh metadata, then check again.
Some clients can play malformed SRT files, but some clients can’t.
I’m saving it as UTF-8. What is BOM?
Subnets are above my network know how.
Is it possible to connect the server via ethernet to the router to test if you get can get a “local” connection instead of remote/indirect?
Are you using the program Subtitle Edit? There is an encoding option for UTF-8 with and without BOM. I don’t know what BOM is but I think it’s better to not have it. That’s how all of my subs are saved.
His first priority should be to resolve the network.
The subs likely have positioning for 1080p and when it is transcoded to 480 they appear somewhere off screen.
Great. How do I resolve the network?
FYI: the subs do not have any positioning and … remember … subs for other movies work on my SONY BRAVIA and subs for this movie works on my VIZIO TV!
