Server Version#: unknown
Player Version#: Plex for LG 5.68.2, Platform 4.4.0
When using the pointing functionality on the Magic Remote by first shaking to show the pointer, selecting the first tile and only the first upper left tile on the library or home tab will instead select the tab on the left navigation whos y coordinate is the same as where the pointer clicked from. i have tested not using the pointer and only using the dpad. i have tested selecting with the pointer the second (horizontally to the right) tile. i also tried selecting the tiles in the row below tcurrently displayed one. it is only the first tile on the row. even if you use the dpad to shift tiles in the row to the left and then select the first one it doesnt happen.
