LG Plex collections (and TV series) layout
Server Version#: 3.95.2
Player Version#: 3.105.0
Hi guys, just bought an LG OLED55C8 and I was testing the Plex app (updated to last version).
While it works well, I’ve noticed it shows collections and TV series episodes in a long line, instead of usual grid view like in this server screenshot:
Is it possible to replicate the server interface, that’s easier to browse?
Having more than 10 episodes or movies in a collection is really a pain to view and choose.
Thanks.
Version is found in Plex app setting/About or in Devices in the Web app
Thanks. Version is 3.105.0.
So, any way to change the layout?
I also noticed Magic Remote doesn’t work.
Thanks.
I have a LG OLED65B8 and the magic remote works well, please expand on what does not work. I currently have opted in to the UNO UI .
However I have read, sometimes you must unpin and re pin some left menu items to function but that about the total I have seen for UNO bugs
You’re right SE56, I should explain the problem more in detail.
I have an LG 55C8 and the pointer of Magic Remote works when I select an element. But I can’t use the scroll wheel to move on the screen, and I can’t grab a point and then use the movement to scroll it (like a finger on a smartphone’s display).
So the Magic Remote is only useful to select something that is already on the screen. To access other sections I’ve to use the arrow keys.
Yes the magic remote does not exhibit all the functions of Scroll on a Mouse or touch of smartphone nor should it… This UI is not touch optimized on a LG TV.
In a Library of more than one screen of posters ,the scroll on magic remote still has a worth while use. Activate so the pointer/cursor appear in a large Library and on the far right a A-Z vertical menu appears that you can navigate to your desired area using the magic mouse. Example: Movies/ Mission Impossible. Use “M” in right menu to navigate directly to movies starting with “M”.
