I like the new beta interface of the official plex app on WebOS but I still use the xplay app instead.
The main reason is because you can’t click with the magic remote in the timeline of the actual movie.
I hope the developers read this topic and think about an implementation of this feature.
Yes, the Magic remote and timeline does not work with the Pointer but the arrow function works well. No biggy same result with the new UNO preview.
The only useful use of Magic Remote pointer is in larger libraries with navigation using the right hand A-Z menu.
As this release is a preview, it is not hard to believe the pointer will gain more gestures. If you wish to make this an official request you need to add it to the following page.
